Does anyone have pictures of the big ninja lowered with the stock length swingarm?
Created on: 04/24/12 07:08 PM
lschevy
RE: Stock lowered 14's?
04/25/12 1:51 AM
heres a pic of my buddies 14 its lowered with stock swing arm
lschevy
lschevy
speedyme
04/27/12 2:20 PM
the frame is wrapped in a vinyl covering
MATTZ14
04/28/12 12:20 AM
Ischevy
The bike above is mine. It is only lowered 3/4" front and back with adjustable links. I have the Roaring Toys ones that I tried first but it to low with me and my wife on it(me being over 300 with gear)I would sell those if you want them. Technically it is longer lowered but fractionally. If I put the fourteen fender back on it looks even longer.
Speedyme
The frame is a semi custom vinyl I had printed. It was a pretty tedious and time consuming application. I will post a pic. I agree it needed something, and not something blingy. I have not been sure if I liked it since the first side was done, and I think it is going to change. I want the green to be in it instead of just black and white. I couldn't get it with green before.
No frame cover and yes cool pattern. Scott has thought it was air brushed for like 2+ years.
MATTZ14
04/28/12 12:17 PM
No Rook, no problem with the bottles or with all the hand set individual LED's. Got pulled over last summer for more then double the speed limit and he never even mentioned them. LOL
The gauge is for the air compressor and reservoir that is on board that I built and posted pics of.
04/28/12 7:27 PM
yeah? Cops never seemed interested in my "illegal" exhaust either and I've been stopped with it a few times always for speeding. I thought that N2O might be a little less likely to be overlooked since it is a race component, explosion hazard in and out of the engine and also, isn't that stuff a controlled substance as regards dental use and whipped cream propellant?
serious question.
* Last updated by: Rook on 4/28/2012 @ 7:28 PM *
MATTZ14
04/29/12 12:38 AM
No Rook n2o is not a controlled substance,they infuse it with a deterrent so it is not used for other purposes. Medical grade is different but will also work. LOL It is also not an explosion hazard as it enhances the burn, but is not considered combustible on it's own. Basically it cools the air and packs more air into the combustion chamber, that's why you have to increase the fuel.
MATTZ14
MATTZ14
MATTZ14
MATTZ14
04/30/12 1:26 PM
Your welcome. If I had run mine at Maxon or now in Ohio I would sell you mine. That is the only reason I put N2O on it. Just in case I go through all that trouble then not make the goal. I would have one more ace in the whole. Need something to offset my manly figure. LOL Bottles are empty right now.
04/30/12 4:29 PM
excellent...I know who to ask now. that would be the reason I would actually need to use N2O as well. I have a lot more than I can handle for all of my riding but if I go for top speed, I'd be on the spray. Other than that, it would be fun to install and play with. I wouldn't mind riding around with the system on the bike even if it wasn't used on a regular basis. It's definitely a conversation starter.
Kolk1
05/01/12 5:50 PM
Mine is slammed right now while im getting used to the nitrous. I need to raise it up though, im about to do a Memphis trip and no way im going out on a back roading trip with it lowered.
MATTZ14
cjuni
MATTZ14
