The second this full titanium system for the ZX-14R hit the shop floor, I started tearing down the bike to weigh it against that massive OEM exhaust. The stock setup is a literal boat anchor that chokes the 1441cc powerplant, trapping a sickening amount of heat soak that cooks the fairings and triggers a nasty thermal drift in the O2 sensor readings.
Taking the calipers to the header primaries, the millimeter-level precision of the tapered collectors is absolute engineering madness. The material rigidity of this aerospace-grade titanium provides a bulletproof structure while slashing over 10kg compared to the factory cast-iron and steel junk. I’ve been wrenching on the manifold flange alignment to ensure perfectly laminar flow while dialing in the fuel maps to compensate for the massive increase in scavenging.
The reduction in radiant heat is a lifesaver, but with this much flow, backpressure management becomes a razor's edge. For those of you stretching the 14R's legs on top-speed runs: how are you dialing in your AFR to prevent exhaust valve scorched-earth scenarios with these oversized header diameters?
* Last updated by: WebikeJapan on 3/23/2026 @ 7:06 PM *
