Rook, I meant the clear plastic water tight packaging/covering/cover. You could pack the inside with a cotton ball at the door/gate/housing, clip the cover closed. See if that stops the vib
You and me are talking about the same thing then. I think the buzz comes from chattering between the clear plastic case and the camera. Cotton seems like a good thing to try. If you still get the buzz, it's coming from something inside the camera and I don't see any remedy for that.
Yeah, mind is not cooperating when I need to think of what they are called, etc. Don't get old.
We're doing our damndest not to, Hub. The shit's gonna happen. I'm doing my best to enjoy the moment.
Dang guys, I have the camera mounted directly on the fuel tank on one of the provided sticky mounts without the clear plastic box, I thought that was for underwater use only? Do you think the plastic box might quell the vibrations from getting through to the microphone?
If you're not using the clear plastic box, the noise must be coming from inside the camera. You could try using the clear plastic box as long as you have the door with holes to let the sound in.
...I don't know how you mount the camera without the clear plastic box. Do the GoPros have a threaded hole to screw onto a mount now? The GoPros I had, you had to use the clear plastic box because that was the thing that attached to the mount. The camera itself was just a small plastic box. I suppose you could tape it to something to film but why do that when you have the clear plastic box to attach to a mount of some sort?
To answer your question Kruz, no I do not think using the plastic box will alleviate the vibration but you might as well try it.
GoPro Silver, GoPro Black....that's what we had the last time i looked at these back in 2015. IDK what they have now, GoPro infrared and GoPro ultraviolet? I'll probably get a Chinese knockoff for sixty bucks when I buy a new bike cam. The genuine GoPro is probably made in China too. They generally get used for nine or ten videos and then they get retired and nobody thinks about them until they're obsolete compared to the Latest GoPros the Chines are manufacturing and copying to sell at a much lower price.
2024 ZX-14R bran friggin NEW!
