Complete Front Brake Fail
On the way to coffee this am, the front brake was
ok, needed a touch of pumping to get
full action.
On the way back NO front brake at all.
Got home;
I took off the front calipers and sprayed
brake cleaner on the pistons 'guessing' that
one of them might be jammed up (?),
and was able to compress calipers on both sets
to the point that all pads compressed fully
so that opposing shoes came together normally
as I am used to seeing.
I re-bleed the top bleeder, no problem there,
but the bottom bleeders would not bleed,
when opening the nipple the hand lever wouldn't
even budge, and no brake fluid came out of either
bleed nipple.
Is a New master cylinder 'probably' needed?
