Thread: Galfer break-In period??
Created on: 04/19/13 12:44 PM
RE: Galfer break-In period??
04/23/13 5:40 PM
As luck would have it, I have the bike completely defaired right now. I will take a pic of the Spiegler clutch line next to the yet uninstalled Galfer brake line and post tomorrow. If you view it on a good quality monitor you will se s slight difference. I am quite sure my camera will pick up the subtlety in hues.
bankheadd
bankheadd's Gravatar
04/23/13 8:15 PM
Thanks Rooks!
Brock CT Duals Exhaust, Cox Radiator Guard, LSL Frame Sliders, Driven D3 Grips, Throttlemeister, Puig Windscreen, Image Design Seat, Yosh Fender Eliminator, DDM HID 6K Lights (HI/LO), Vortex Frt/Rear Sprocket 16/43, Muzzy Fan, Muzzy Block-Off Plates, Schnitz Secondary Fan, Galfer Rotors & Brake Lines,Stock A/F, EBC HH Pads, PCV w/Brock Map, Speedohealer v4, Pazzo Levers, Flies Out, 0W Alisyn Synthetic Oil, Engine Ice
04/25/13 8:57 PM
with flash
in garage, open door low light
bankheadd
04/25/13 9:05 PM
Thanks Rook, It looks like I'll be looking for that Spiegler line. It is a little darker.
bankheadd
08/14/13 8:18 AM
Okay, I've put about 2500+ miles on my galfer setup and I'm not getting the stopping power comparable to the OEM setup... I even had them adjusted. I'm not getting the initial biting power I would expect from my setup (Galfer rotors frt & rr plus brake lines and new new pads) When I had my Busa, I just replaced the pads with EBC HH and front & rear brake lines... an man! what a difference it made, it was a whole new rideing experince. Any solutions?
