You control the distance between the pipes and the baggage with a homemade bracket. Mine are about 1.5 inches distance from the pipes -- the plastic gets little warm, but that's about it. I wanted the pipes as high as possible, but they certainly could have been dropped more than I did. My writeup is for the 2012 ZX14R -- Twisted Throttle will not openly endorse a product that requires lowering the tail pipes. The part numbers that I listed are the ones I bought and installed in 2012. Unless the product has changed since that date, they should still be the same.
My recollection is that the picture from the post dated `06/05/12 11:43 PM` was with the pipes lowered more than I ultimately decided to keep, and I raised them up a bit after taking that photograph. That required me to use an angle grinder to cut away part of that circular mounting hole so that I could fit the bolt through the cut-away portion of it. The other side of the bike doesn't even have a mounting bracket at that portion of the exhaust pipe, so that area is not critical in my opinion. Tightening the bolt with a washer has held it in place just fine for the last 2 years.
* Last updated by: lawlist on 5/21/2014 @ 3:13 PM *
