Page: 1 2 3
Thread: Brock's exhaust instal problem
Created on: 04/12/13 04:48 PM
RE: Brock's exhaust instal problem
04/12/13 7:21 PM
if your still having trouble dont hesitate to call brocks they have great customer service and will walk you through the install if need be
OneDividedbyZero
04/12/13 9:36 PM
Thanks for your guy's imput, and thanks for those pictures, scott. I ended up having to take everyhting apart, all the springs off and putting the midpipe on (which took half an hour of wrestling with it) THEN atteching everything to the headers; which is back-ass halfwords from the instructions but it worked! after 12 hours, i have the exaust all on and buttoned down. Tomorrow I will install my power commander and put her back together. Again, thanks for all your help.
"It aint a crotch-rocket. Its a crotch cruise missile."
04/13/13 4:42 AM
well glad you got her on. Tip before putting her back together start her up and let her run till she gets good and hot then re-tighten them header bolts.
04/13/13 5:02 PM
oh and you have to get your new exhaust badged correctly lol
* Last updated by: scottjkyl on 4/13/2013 @ 5:04 PM *
bankheadd
bankheadd's Gravatar
04/17/13 11:02 AM
If anyone of you guys get tired of your CT Duals let me know. I've owned my 14 since Sep 2012 and I really like the dual exhuast setup, the bike just doesn't look right without duals. I currently have some V&H CS ONES installed they look nice but I want try duals.
How do you like your gear 16/43? I'm asking because I ordered the same setup. I'm about 240lbs and I was told this is a good setup for my weight and type riding, straight highways & streets. I like fast accelration.
* Last updated by: bankheadd on 4/17/2013 @ 11:03 AM *
Brock CT Duals Exhaust, Cox Radiator Guard, LSL Frame Sliders, Driven D3 Grips, Throttlemeister, Puig Windscreen, Image Design Seat, Yosh Fender Eliminator, DDM HID 6K Lights (HI/LO), Vortex Frt/Rear Sprocket 16/43, Muzzy Fan, Muzzy Block-Off Plates, Schnitz Secondary Fan, Galfer Rotors & Brake Lines,Stock A/F, EBC HH Pads, PCV w/Brock Map, Speedohealer v4, Pazzo Levers, Flies Out, 0W Alisyn Synthetic Oil, Engine Ice
04/17/13 1:41 PM
bankhead, i really like the gearing setup. with the oem setup i was rarley ever able to get the bike into 6th gear unless i was highway riding lol. the acceleration is out of this world be careful the front end grows wings really quick. and if you really like fast accel then spend the $25 and get the rifleman 1/5 turn mod best mod for the $$$
bankheadd
04/17/13 6:02 PM
Scottjkyl
What is this 1/5 TURN MOD you speak about and what does it do? I've never heard of it? Will this interfer with my Throttlemeister?
04/17/13 7:13 PM
I went up 2 teeth on the back and now my computer is pissed off.
04/18/13 1:10 PM
bankhead heres the forum thread on it ill let you read thru it
1/5turn
bankheadd
05/17/13 9:53 AM
Hey guys, is that header gasket reuseable or should it be replaced? I haven't looked closely to what I received from Brock with my exhaust in regards to the small items.
1. Also onedividedbyzero and scottjkyl, is it easier to install headers w/ the x-pipe/mid pipe installed? or W/O the mid/x-pipe installed?(not sure of correct name).
2. Also did you guys use any lube or WD-40 to easy the fitting?
3. Is it easier to remove Rad to do this install?
05/17/13 2:29 PM
You could reuse the gasket BUT you should replace them, got mine from schnitz racing. I was going to tell you to order some but I forgot!
It's easier to remove the radiator, plus since you're going with engine ice, just empty it and remove it. Search the forum, there is a thread for installing the duals. The guy said is was easier to remove the radiator. Just retightening my bolts was a PITA with the radiator on but I have got large hands.
bankheadd
05/18/13 5:20 PM
Thanks dragking I to have the large hand problem. So did you you any kind of lubricate to easy the installation of fitting the pipes together?
05/18/13 7:42 PM
They shop I purchased the exhaust through did the install. You should ask Brock. I bet they have an how to video on their website though. Or you could follow these guys instructions:
Leo Vince Full Ti install
bankheadd
05/27/13 11:17 AM
Hey I'm install my CT Dauls today and I have a question?
1. can I use the anti seize lube to hold the new o-rings inplace? they won't stay inplace at all.
05/27/13 1:14 PM
If you mean the new header gaskets...I would pick up a can of Permatex high temp sealant at the auto supply. Spray one side, let dry spray other side let dry, coat a second time, stick in manifold while tacky, they will stay in place.
bankheadd
05/27/13 2:01 PM
O, Ok. Rook here is my situation now, I have my headers installed but when I go to tighten the nuts up they seem to be getting way to tight and I have no threads showing thur the bolt. I would think the flanges should be flush with the motors flange? See pick
05/27/13 2:04 PM
No...they won't be showing...not like the stock headers.It's okay.Just make sure they're torqued correctly.Mine looked just like yours...and this deal was a concern to a lot of guys switching over.Mine were fine...as yours will be also.I think even Brock was asked about this on his site...you could probably check it out on his forums there.Maybe it was mentioned in the instructions...I know I either read it on his site,or in the instructions.
I thought the same thing..."this doesn't look right"...but it was.
* Last updated by: Grn14 on 5/27/2013 @ 2:07 PM *
bankheadd
05/27/13 2:54 PM
Grn14 thanks for some assurance, the instructions says to torque to a max of 10 ft-lbs. I don't own a torque wrench so I will verify my torque before I put it back together.
05/28/13 7:47 PM
Get an inexpensive flex beam and needle torque wrench.
CLickers can be way off until you calibrate them which is whole nother littlke project. You prlly want to jusyt ride so get flex beam torque wrench. Go for one with a smaller range rather than a large range. 0-40 foot pounds will be more accurate than 0-75.
Don't over torque. Less is more. You can always go tighter. doesn't help to go looser after something strips or breaks. (ask me how I know)
bankheadd
05/29/13 8:09 AM
Man I tell yeah! I had to disassembly the headers to get the springs attached to the backside of the headers then I purchased a digital torque wrench to torque the header nuts to 10 ft-lbs which isn't enough IMO, but hey, I'm not an expert.
05/29/13 9:08 AM
How about some plain old bearing grease?That works pretty well.Not sure about wd40....whether it'll stain the pipe or not?
Dis is abstract. Dis is what I go after. Ever use bearing grease for chain lube? How about any chain lube? Ever see that oil fall on the stainless and stain it? The grease will boil out of the two joints even if you clean the seams around the pipe. Exhausts go on dry. So yeah it works pretty well for assembly I agree. But never start it up. I'm just the messenger is dis message is boughto you buy dking is he mentions dis pick able is pluck them out of the barrel in a post I read. Anyway, lets move on to WD40.
Lets say a pipe maker that sponsored me, made me pipes to my bend specs. Schooled me on WD. They were a raw finish so he told me to wipe them down with WD so it wouldn't rust. And it was to be put on while hot at the headers and down the pipe is smoke the towel wipe. That's what I did with someone bending pipes for the nephew's chopper before he had them chromed recently. I could see where there was a flame or heat burn down the pipe. It was 8 to 9 inches was this bluing. I'm thinking it's a rich area; the cool air coming in can only be cool for so long. As it enters the pipe, moves down those inches, she backfires right there. Just farthinking shitting here.
* Last updated by: Hub on 5/29/2013 @ 9:10 AM *
05/29/13 9:31 AM
Are you positive that all the old header crush washer were removed before installing new ones ? It can happen, easy to miss.
bankheadd
05/29/13 2:07 PM
The four o-rings came out with no issue and then I cleaned each inlet up. I contacted Brock Davis and sent them pic's and he said everything looked normal and there is no issue.
05/29/13 3:15 PM
Thanks, Kof
I don't know if you are still having trouble, bank, but you can run the assembly like this.
1. I want new gaskets. Rook's deal is find IF I use the old gaskets. Crush is what I want with new.
2. I want zero goop, oil, spray, in fact, I want all my oily hand prints off the finish is some vinegar and water in a rag or paper towel. Even a lint free all watered up will not scratch the finish. I want it wet clean of that acid too, so I'm not soaking the crap out of it and the heat and all that cooks it out with more stains to it.
3. I have a clean port because I do not want my O2 to be contaminated in any way or pay for a poor running bike and all those chemical band-aids I steer away from.
4. I am going to assemble the header and looks like I need the mid pipe to keep the 4 headers in line.
5. I'm going to assemble this one piece pipe; line up the fronts into the ports; with a tiny dab of grease to hold the new gasket in place.
6. I have the collars floating in place and I am shaking the whole header system with one hand and hand twirling the exhaust bolts with the other.
7. I have this pattern to follow in the book, so I am going to be close by alternating a far nut to the inner nuts, or inner bolts out to the farther bolts, I just need to shake and make a pattern so the 4 headers float to their own home.
8. I'll feel that header tighten up all snug. This is where I do not need, nor use a torque wrench, but to hand tighten these wave washers enough not to crush the gaskets down just yet.
9. I now let my header float where it is all pretty well tight, but will gloss over the nuts one more time. And snug as in not to pull the studs out of the head, nor curl the stud's threads off their stem. It's were you can tighten this special washer that is the stopper from spinning off. But by hand with a socket, I can swap and swap pipe and still hand spin the nut back on, it's that soft a touch without the torque wrench and knowing thread sheer is a heli-coil away.
10. I'm at the back of the bike. I'm about to 'slip it on.' And if I can't; and if I have to undo the header nuts; and if I have to drop the header to fit the slips; I do not buy bent pipes all jiggedup; is it's fucked up; send it back; give me that crap.
11. But if it fits perfect = It's the Fitter! [struggling at it] is how you assemble it without instructions. It only fits one way and if it's welded all off, then off to the manu it goes. Something needs to line up in the static and it ain't happening.
05/29/13 6:51 PM
That is a really good point, Hub. Never even occurred to me. If a pro tunes the bike, he will prolly sniff for more than just oxygen. If tuning with o2 sensor alone., I don't see that minute amounts of extraneous gasses would make a dif. ??? Best to keep things as simple as possible....however, should be noted every pipe is going to come with some kind of sealant in a small sample tube.
Ya, bank...was gonna tell you about Hub's old grease trick. Never tried that because I used the permatex on both pipe installs I have done. The grease would burn away after a few minutes of running the engine.
Page: 1 2 3
