Thread: Head Shake
Created on: 01/29/17 01:35 PM
mebgardner
mebgardner's Gravatar
RE: Head Shake
02/07/17 8:02 AM
Oil Change.
I thought so. Thanks.
I asked my service manager about this service, and he's a long time manager at this (now closed permanently) dealer shop.
His advice was to leave it alone, not do it. I thought it odd advice at the time, but also considered that he knew what he was doing to run his shop and customers.
What do I know, huh?
Guess I'll git'r done.
RE: Head Shake
02/07/17 12:04 PM
Tires were inflated pretty high - probably a pound over the 42 the manual suggests.
Not it.
The PR4s are worn out - just at the wear bars. Never had any head shake previously and I'm at 11,400 miles.
We have a winner! If it was chassis it would have shown it at any speed or bump. 11k is nothing on this bike and the engine grenaded that soon?
piken
piken's Gravatar
RE: Head Shake
02/07/17 12:41 PM
Straight weight oils don't break down like multi weight oils, so they do last longer
in that sense.
But the will lose lubricity and even though there is no combustion process the
oil still gets dirty.
When you talk to a suspension guy, they will tell you annual changes, including the rear shock.
Here's a photo from when I changed fork oil on my ZZR. Looks a little over due to me.
mebgardner
RE: Head Shake
02/07/17 12:55 PM
Yeah, that look a bit overdue.
... including the rear shock
I've never had a rear shock serviced, ever. Hmmmm.
piken
piken's Gravatar
RE: Head Shake
02/07/17 1:54 PM
Little harder to do rear shock.
I have to send it out to be done.
You need to vacuum/pump the rear shock when changing the oil. Thought
about buying a pump a couple of times, but long way down my list.
Rears need oil changes and check nitro charge to make sure bladder hasn't leaked.
Should do dampers too.
