Thread: best way to help my 06 bottom end..?
Created on: 12/12/12 11:52 PM
Nightmare
Nightmare's Gravatar
RE: best way to help my 06 bottom end..?
03/10/13 10:22 PM
Yeah ditto on the new screw driver, when I did my subs I heated them using a soldering iron (melted the "lock-tite") just propped the iron up on the screw and let it sit for a few mins, then use a REALLY good screw driver (if it looks slightly questionable don't use it, if its a really pointy tip, DON'T use it). I had a new screwdriver that apparently sucked... had a helluva a time getting the screw out, switched to an old crappy screw driver that I don't care about, and the screws came out like nothing :)
Kolk1
Kolk1's Gravatar
03/22/13 4:39 PM
FYI: if you want to do a -1 front, buy a OEM Zypher front sprocket. Its a -1 compared to a ZX14, BUT it still has the OEM rubber bushings on both sides, so its not loud like a vortex.
2007 Plasma Blue ZX-14.
