geez.Well,Rod says the sensor will cause this stuff.Hub suggests checking the connector sleeves.I say meter assembly.Wow.Kawi says..'hey,we have NO idea"...in a roundabout sorta way.New ECU worked...fine actually.Along with your original.And Mama Kaw is scratching her head thinking 'what's a mother to do?'.This is a good one,ominousone.
Maybe it just needs to be cycled like the Hubmiester says.It does run okay now,right?I know cycling the key works...how many times,that I don't know.
JUst by your description,how the needle sweeps and such,yet the display is koo koo...it sounds like the display function has been damaged.Maybe have em swap a meter assembly for ya...just to see?That would eliminate that part anyway.I mean,since they're trying everything else.I switched tire sizes.Sprocket sizes(front and back(16T and 40 something)several times...no issues ever.Havin a hard time thinkin that's your problem....
Can you turn the KTRC 'off' with it like it is right now?I'd try that anyway.See what that does.It is running,yes.And running okay,right?It's only the dash that's acting weird?
* Last updated by: Grn14 on 9/15/2018 @ 8:13 AM *
