Thread: It's time....
Created on: 06/21/11 09:28 PM
RE: It's time....
07/23/11 9:15 AM
One of these days I am going to add up all the few ounces I have shed from the bike. I always take scale pics. You guys know if you read the threads. I'm sure it has been at least 15 lbs not including the weight loss of going to a full system. I just lost another 1.5 lbs going to aftermarket mirrors. Yeah, no point in even trying to get down to the weight of the smaller bikes but I will take a 50 lb reduction. That makes a huge improvement in a 14's all around performance. I'm thinking seriously about a set of Carrozzerias.
Donny
Donny's Gravatar
RE: It's time....
07/23/11 4:12 PM
I got 4 yrs out of my stock battery, put a replacement one in, I find it helps if you trickle charge 'em every month or two.
www.drblast.com
RE: It's time....
07/23/11 5:30 PM
Or you could wait a little longer save a little more and get some BST's. I heard the back their hype up and then some. That's more than half of what I have paid for my bike but if my insurance can insure most of my upgrade at a minimal cost, I'll splurge on them maybe next year after I file taxes
RE: It's time....
07/23/11 5:46 PM
oh! and time for the stupid question: Can you put a shorai on battery tender and if yes is it needed or recommended?
RE: It's time....
07/23/11 7:51 PM
I would email Shorai but I am quite sure there was a certain kind of conventional charger that would work on the Shorai. Kruz mentioned that in one of these threads---the old Shorai thread from January.
It is my understanding that the Carro Tri-R is the lightest wheel. Lighter than BST and less expensive.
Romans? Dogo??
maybe i will start a Wheel thread.
RE: It's time....
07/23/11 8:50 PM
Nice. I'll check into that!
RE: It's time....
07/23/11 9:15 PM
from shorai website:
Q. Can I use Lead-Acid battery chargers or charger/tenders?
A.Yes. HOWEVER, you may NOT use a charger/tender if it has an automatic "desulfation mode", which cannot be turned off. We have confirmed with Deltran, makers of the "Battery Tender" brand, that their products do NOT have a desulfation mode, and are therefore OK for use with Shorai LFX, for example. But the best possible charger/tender for Shorai LFX is the SHO-BMS01, which will be released on about March 15th 2011, we expect. It uses the 5-pin BMS port in the LFX batteries, in order to monitor, diagnose, and balance the individual cells during charge. And it also has an optimized storage mode that will give the longest possible service life to your LFX.
If you are storing your vehicle and want to check the remaining capacity, or you're a racer with a constant-loss system, you'll want to know how resting voltage (i.e. with no load or load under 200mA) maps to remaining capacity. LFX batteries should be maintained such that 20% capacity remains at minimum, as best practice. Use a good-quality voltmeter to check remaining capacity, and consider recharge whenever the battery capacity falls to about 50% remaining. Of course, if you get the Shorai dedicated BMS01 charger, you can just hit the "Store Mode" button and leave it to do the work for you.
RE: It's time....
07/24/11 9:36 AM
^^Thanks, Scotty.
Let me know what you come up with , Drag. I always hear "BST, BST, BST" but then someone chimes in that Carros are lighter and they are less expensive. Personally. I wish the Carros were a little less fancy in shape. I would get the blue finish but I like parts that look more down and dirty race utility when it comes to shape.
Good luck finding the exact weights. IDK why those specs are so hard to find.
RE: It's time....
07/24/11 12:46 PM
Carro wheels site:
We also offer a Hi-Gloss Polish (+$200) Additional (+250) 240 Wheels
Super Light Weight 7.2 lbs (front), 12.7 lbs (rear) (08 Busa)
Approved DOT (USA) & JWL (Japan)
One Year Limited Warranty (No warranty on 240 Wheel Sets)
Wheel Kits include: Cush Drive, Japanese High Quality Bearings, Spacers and Carriers.
Most Applications do require a Kawasaki Bolt Pattern Rear Sprocket.
Available for Most Modern Sportbikes, See Below for Applications!
TRI-R FORGED WHEELS
Newly Designed Wheel exclusively for the Ultimate Light Weight!
Made From Wrought 6151-T6 Forged Aluminum/CNC Full Machining.
30,000 M/Ton Super Die Pressed
Proprietary New High Heat Forging Process
Proprietary New Full CNC TRI HUB Design for Strength
Rivals the weight of Magnesium, but made from super strong Forged Aluminum
Weights (Bare) Front 3.50/17 = 6.1lbs
Rear 5.50/17 (8.0lbs) - 6.00/17 (8.5lbs)
looks like bst is front: 4.6-5.95 lbs rear: 9lbs
bst
* Last updated by: scottjkyl on 7/24/2011 @ 1:00 PM *
Slowninja
RE: It's time....
07/24/11 1:28 PM
Donny, no offense intended but you don't know what you're talking about.
Take a completely stock bike to a scale. I'd guess she weighs in about 530lbs.
15lbs for the exhaust. 10 lbs for the battery. 15 lbs for wheels (if you throw the $$ out there). That alone is 40 lbs, putting the "big gal" at 490 lbs.
Take your bike, and a bike set up exactly like yours with a rider that weighs 40 lbs less. Go out on the highway. Watch his taillight disappear into the horizon.
Weight is a HUGE factor on sportbikes. My bike weighed 470 lbs last year. It all adds up.
Resident Drag Racing Expert.
ZX-16 in 2010
8.64 at 158 on motor
8.28 at 173 on nitrous
Back to stock for 2011.
9.24 @ 148
185 hp pump gas
RE: It's time....
07/25/11 3:03 PM
So--Tri R is 14.0 lbs for a set of ZX-14 wheels.
BST CF is going to weigh 13.6 to 14.95 lbs but you do not specify the wheel size and your link is not working for me. I would be pissed if I bought BSTs for a grand more and found they weighed a pound more.,....but they DO look more like a sportbike wheel IMO.
Anyone have the final verdict?/ I know who knows the exact weight of a set of Zx-14 BST wheels. anyon know how to contact MassZX-14?
RE: It's time....
07/25/11 3:17 PM
I weighed my baby...540 lbs with half tank of gas,TiForce slip-ons.No rider.All stock wheels,and stock parts.
* Last updated by: blue07 on 7/25/2011 @ 3:17 PM *
RE: It's time....
07/25/11 3:55 PM
I believe that the 06-07 north american 14 weighed in at 555lbs wet,now was that a full tank of gas? Maybe its japanese lbs. Anybody have access to a scale
RE: It's time....
07/25/11 6:58 PM
rook, just google blackstonetek (bst) they specify wt by wheel size not bike specific. the weights i posted were the std wheel size on the 14
RE: It's time....
07/25/11 7:12 PM
zx14 bst......
SIZE : 6" x 17"
WEIGHT : 10.65 lbs. (4.83 kg) with sprocket carrier and hardware (without sprocket)
Add 1.05 lb. (0.476 kg) with Worldwide Bearings ceramic bearings
Add 1.15 lbs. (0.521 kg) with Worldwide Bearings steel bearings
STATIC LOAD RATING : 550 lbs (250 kg)
Click Here: Important Load Rating Safety Information
MATERIALS : Carbon fiber and aluminum
STYLE : Slanted, five-spoke configuration
VALVE STEMS : BST Ultra-High-Speed (UHS) 90-degree, aluminum stems and caps
APPROVALS : DOT for street use - Race sanctioning bodies
FITMENT : Direct OEM replacement - Aftermarket sprocket required
WARRANTY : 2 Years
SIZE : 6.25" x 17"
WEIGHT : 9.75 lbs. (4.42 kg) with sprocket carrier and hardware (without sprocket)
Add 1.05 lbs. (0.476 kg) with Worldwide Bearings ceramic bearings
STATIC LOAD RATING : 640 lbs (290 kg)
ANTI-SLIP COATING :Standard
WARRANTY : 2 Years
SIZE : 3.5" x 17"
WEIGHT : 5.65 lbs. (2.56 kg)
Add .40 lbs. (0.181 kg) with Worldwide Bearings ceramic bearings
Add .45 lbs. (0.204 kg) with Worldwide Bearings steel bearings
STATIC LOAD RATING : 330 lbs (150 kg)
WARRANTY : 2 Years
* Last updated by: scottjkyl on 7/26/2011 @ 5:56 AM *
Slowninja
RE: It's time....
07/25/11 8:35 PM
Dayum. How'd i get mine to 470 i wonder?? Jeesh
ZX-16 in 2010
9.24 @ 148
185 hp pump gas
RE: It's time....
07/26/11 7:14 PM
Just checked kawasaki canada,2011 14 weighs 555 wet,gas tank 90% full.My 07 should weigh in at about 505,BST's S-meg,Shorai battery and a full tank of gas
RE: It's time....
07/27/11 11:54 AM
Update:
got new Shorai 18a installed and put it to the test so far so good even with the 300+ leds on for over 4hrs it shows no sign of slowing it up any. thinking im gonna like this battery.
RE: It's time....
07/31/11 9:51 PM
Do the stock positive/negative cables bolt right on the 18A or do you have to modify them to fit? Thanks.
