Thread: Died at idle twice- Had a couple check engine lights
Created on: 04/24/16 02:40 PM
extrapolator
extrapolator's Gravatar
RE: Died at idle twice- Had a couple check engine lights
06/20/16 9:55 AM
Happy ending to the story.
BTW I think bikes dying while idling up to a stop sign can be due to the motor running slower, therefore the alternator turning slower, therefore the alternator outputting a lower voltage, just enough lower to no longer be able to overcome the higher electrical loss (ie resistance) at the loose connection.
=x+rap01a+0r
darkarcher
darkarcher's Gravatar
Cincinnati, Ohio USA
06/21/16 6:24 AM
Had a friend once with a CBR and a similar issue. His problem ended with a tow and a mass of melted wires under the tank. Not sure what caused it be inspect your wiring harness.
2020 on the way!!!!!!
