Thanks Grn14,
Anyways, something very new happened today. For the first time ever, my bike's brake actually compressed. I know it is hard to clearly explain this, but before i worked on the bike this weekend, when i would grip my lever, i would maybe pull it down 10+% and it would stop. I would just barely touch it and it would be full braking. Well, today, it felt like a regular lever. I think i pull about 20% and it starts and then 50% for full braking. Something like that. When i bled the brakes again, i really drained a LOT of fluid out of it. I never completely emptied the system. I don't have the tool to take the calipers apart. That reverse star socket. So i did all the work with pushing the pistons almost out, but not completely out and then manually spinning the piston and cleaning it. I know i should completely disassemble it, but i was not able to yet.
Anyways, i think that something that might of been clogged might be fixed now.
Thanks for the advise. Can we use new pads on old rotors? As i said, the rotors are about 4.8mm thick. The service limit is 4.5mm. I thought we were always suppose to replace together, but damn, the rotors are so damn expensive!
The other side's pads are fine, so i was thinking i would just get one set and try to match the model.
And to your other question, i do not notice a difference in color between the left and right side of the rotor. I will let you know about the fluid level. I always fill between low and high marks.
* Last updated by: viperkillertt on 4/30/2012 @ 10:47 AM *
