So how are they making engines out of aluminum?
Instead of cast iron sleeves bored to fit the aluminum cylinders, they now spray a silicone base to the cylinders and hone to fit the pistons. Notice no size over pistons for reboring like the old days. Sure you can have the cylinder resprayed and fit for oversized pistons, but you'd have minimum wall clearance boring thru the water jackets. The rings would eat the aluminum being so hard and minimum oiling. Where a set of cams mounted within the aluminum half caps are bored for clearance and the oil pressure surrounds the cam to float in the bore holes.
Aluminum is not malleable to shape a curve like the header needing to turn down from the head. The aluminum would crack when it would curve. An enclosed muffler, sure, its straight when made.
