#1
On the WRT website, they outline the things you need to flash a bike. One is the Bin Definition File. If WRT software doesn't come with your bike's bin definition (which are all Suzukis), you must buy the Bin Definition File to even have a chance of reading or writing the ECU. Let's take x ECU for example.
The Bin Definition File for x1 is permanent. The purchase of the Bin Definition for x1 includes 1 Bin Definition Flash Key. You flash x1, this consumes the BDFK included. If you want flash x2, you must buy another BDFK for x ECUs. Now, after flashing x1 or x2, subsequent flashes do not require a new BDFK. However, you end up with x3 (doesn't matter how) when you go to flash it the software's going to tell you that you have no keys left.
NOTE: I cannot be held accountable for descrepencies on WRT's website.... as far as 1 or 3 keys.
Per the WRT Support Website:
Each Bin File Definition purchased entitles you to three keys to flash three separate bikes/ECU's. If you want to tune more than three bikes, you'll need to buy another key/s.If you're a tuning shop or dealer, and you purchase an annual bin file definition subscription to a particular make of bike, you may flash as many bikes as you like for the period of the subscription.
Note: The Keys do not apply to the free bin file definitions, you can flash these ECU's as many times as you like.
From the ZX-14R Product page:
Purchase this item to gain access in the Woolich Racing Tuned software to the stock bin files for the 2012-2015 Kawasaki ZX14R / ZZR1400
Features available for Kawasaki ZX14R / ZZR1400 2012-2015 IAP Fuel Maps
TPS Fuel Maps
Ignition Timing Maps
Secondary Throttle Plate (STP) Opening Maps
Fuel Trim Maps
Adjust RPM Limiters
Disable Top Speed Limiter
Disable Stock O2 Sensor
Retain last Traction Control Setting
This product comes with 1 Bin File Definition Key allowing you to tune 1 ECU's as many times as you like. Additional Bin File Definition Keys are required for each additional ECU's and can be purchased from within the WRT software.
So maybe I have the price wrong, maybe it's not $100 per key, but it does have to be purchased.
#2
Yeah this I don't know, I'm asking more than I'm telling. I'm not sure if every change requires a flash/reflash or not.
