Introducing “The OMFG flash” that’s right now available to the general public for the first time for a limited time. We basically took a Viagra pill and turned it into digital code, and then we downloaded it into an ECU. So get yours NOW. What are people saying about the flash, nothing because they’re dead? That’s right put this flash in your ECU and you will die. Do you want the ultimate riding experience before your bike blows up, than this flash is for you? While other flashes have LAUNCH control, we have LOST control, that’s right, pull the clutch in and grab a handful of throttle, and then release the clutch, Out of control. Now I know you’re asking yourself, this sounds too good to be true. It isn’t, what does the OMFG flash have, well, the RPM limit was raised to infinity, that’s right no more pesky Redline, we removed the top speed limiter because you will die before you hit maximum speed anyway. You also get decreased fuel economy, whose counting mileage when you’re trying to go as fast as you can, am I right. Now I know you’re like how much is this remarkable flash, now wait, if you order the OMFG flash within the next 30 minutes, we will send you two OMFG flashes. That’s right take a buddy with you, on your ride to oblivion. Now, here is the best part, the OMFG flash is FREE, that’s right I said FREE. All you have to do prior to us sending you this remarkable flash is put on your life insurance policy, that’s it. Amazing right. To get in on the OMFG flash, all you have to do comment below that you want the flash, and then we will contact you.
