I have upshifting clutchless down to the point
where most of my upshifts are clutchless but
under some circumstance I still like to 'clutch'.
I'm doing a lot of downshifting now clutchless, too,
but could use some tips/hints on getting them better.
The way I'm doing it so far is getting the motor
and trans in a semi neutral attitude where there
isn't much pressure on the trans in either direction,
kind of tricky as I'm doing this while decelerating,
so to make that 'neutral' force possible while
I'm decelerating I then add just enough throttle
to bring the bike back to 'that' neutral or unloaded
state, then I very quickly decelerate and accelerate
and snap the shift lever into the next lower gear.
It's kind of like a reverse action blip that we
do on upshifting clutchless.
I saw a video where the rider was explaining and
showing that he'd pull on the front brake lever
and roll the throttle someway at the same time,
kind of stabbing at both at the same time,
I couldn't quite grasp how that was working.
I'm sometimes just doing the engine brake until
I need the braking action , but other times
braking steady with front brake and reverse blipping
the throttle.
Any hints/tips would be appreciated.
