Thread: Rainy day and ZX14R
Created on: 01/16/16 07:28 PM
OldMan
OldMan's Gravatar
San Jose, Sunny California
Rainy day and ZX14R
01/16/16 7:28 PM
I don't ride in rain but what if I am traveling and hit a sudden thunderstorm or something. ZX14R has a huge opening up in front connected to air filter. Does riding rain affect performance? What should I do after riding in rain? Dry up air filter??
1973 Suzuki GT250, 1976 Kawasaki KH500A8, 1979 Yamaha RD350, 1985 Yamaha Maxim700X, 1987 Kawasaki EX500, 1994 Honda CBR600F2, 2004 BMW R1100S, 2005 Kawasaki Z750S, 2003 Suzuki SV1000N
RE: Rainy day and ZX14R
01/16/16 8:34 PM
I never noticed a performance change. It would take a hell of a downpour to really get the filter dripping wet. I would just keep an eye on the filter and change as necessary. Is there a air box drain tube with a bottle on it like the Gen1 has? If so, I would not even worry unless you find water in that bottle.
rod442
rod442's Gravatar
01/17/16 11:15 PM
Rook nailed it. there's a little drain bottle you could check for water.
Ive been in some torrential downpours where the cars on the freeway were slowing to under 30mph and just so I could see I was passing people at 75+ to get out in front a bit and have the rain-x start working on my visor. Below about 50 it doesn't help much.
Just parked the bike when I stopped. Didn't ever check the filter. seems to be fine.
and PS there was so much water that after I got my waterproof boots off, there was almost a cup of water that I wrung out of each sock that had come in from the tops where my jeans were tucked in. lol.
* Last updated by: rod442 on 1/17/2016 @ 11:16 PM *
zx14rider345
zx14rider345's Gravatar
01/23/16 8:51 PM
I also got stuck on a trip from Maine to CT. It was a solid 2.5 hours of rain from heavy to light but it rained the whole time. I never thought about that huge ram air hole. Bike never skipped a beat. Hopefully the engineers took that into consideration when they designed it.
2012 ZX14R, 2016 BMW S1000XR
ZX14MAN64
ZX14MAN64's Gravatar
01/24/16 5:37 PM
2.5 hours riding in constant rain? Yowwww!
I HATE getting caught in rain. Do my best to avoid it if at all possible
01/24/16 11:01 PM
The little clear catch tank at the bottom left side near the side stand. This hose/catch tank is sealed and is a rain drain/oil catcher that empties the ram just for those incidents. Simply drain it and you are done.
Cool, condensed air is a performance enhancer. You may feel it run smoother on some days or not without rain. It's subtle against the [sensor] telemetry.
No: Fairly clean, the air of the engine needing that much volume is an air dryer and will dry within minutes of sustained dry riding. Riding all the way home in the rain is still semi-dry having that air move across it. No need to mess with it.
Depends: Say you are 3/4 in on the service interval. I'd say it's done. The rain soaks it... where the dust is loose, but to get it wet and spread the dust to a caked effect over the pleats? It's far from being cleanable but rather replace it.
* Last updated by: Hub on 1/24/2016 @ 11:03 PM *
motero
motero's Gravatar
01/25/16 11:51 AM
yep, throttle will feel a little crisper in cooler air, we probably have more wet days than dry days here, never effected any bikes i had in 25 years of wet riding,
your air filter should not get wet, i turned my trials bike upiide down in a river last week, it still ran after a good few kicks, filter had some water in it, not a huge amount for a bike that wwas submerged for a few seconds,
the zx will be fine
* Last updated by: motero on 1/25/2016 @ 11:53 AM *
2012 black zzr 1400,
sherco 290
sherco 305
01/25/16 1:04 PM
Also, steam cleans the carbon off parts, which lowers compression, which decreases knock/pre-ign. Ask me how many head gaskets I've changed when the radiator coolant enters the combustion chamber.
Nightmare
Nightmare's Gravatar
01/25/16 8:23 PM
Hub, how many head gaskets have you changed when radiator coolant has entered the combustion chamber?
01/25/16 8:47 PM
How many hade gaskets have you changed due to the gasket was the reason coolant was entering the cylinder?
01/25/16 11:44 PM
Enough to know the effect of what happens... fucking wise guys!
