.Brock hit 220...rear wheel...most likely more by now;)
Nah, Brock is done. He's a business man, he would have publicized any HP gains. The only thing he had to get sorted was the flash, courtesy of Guhl. He didn't even have to make a specific 14R pipe. It's not like the 1st generation. No need for a ZX-14R diary either. Everything was pretty simple, except for the stock ECU which would default to a low power mode.
Drag says..." Would love to try that beast with TC off on my favorite back road!".....hmmmmm.....interesting.....unless ya have strong ass ankles...to keep er vertical that is;)
I'm a big believer that more power doesn't translate to more danger. I read you were saying the mods you did made you ride like you were a pro on a circuit but apparently your accident wasn't caused by the power of the 14. Lack of skills or attention (not saying you lack either)is way more lethal than HP! Furthermore, the 14R has got a lot of power but with its clearance limit and weight it kinda tame you down a little. Although it weight less and doesn't have TC, I think I would be OK, if mine put 205-210hp at the rear wheel.
@SparkyG: Too bad you couldn't bring the S'tho or the Panigale over there to compare. I'm curious to know why you chose 2500 miles as the time for the custom tune. You think the motor will be fully broken in by then?
* Last updated by: dragking on 1/4/2013 @ 8:53 PM *
