Thread: Any one sent there seat
Created on: 06/05/10 07:36 AM
rebus20
rebus20's Gravatar
06/05/10 7:36 AM
to spencers for an upgrade? I have a sargent seat but its only the front and I am going to have to use the stock seat for a trip next month( around 1400 miles in 4 days) so I was debating sending the seat off the have it redone. He told me $75 plus shipping. This is part of the email he sent me and it sounds promising.
With your ZX14 riders area the angle can be biased more to the rear, for a more neutral position, and rotation of the hips that also helps your reach and makes it a much more comfortable riding position overall. The pan does limit what can be done to the seating position, front to back, will remain the same. Adding the Supracor/LD suspension is a necessity in this riders seat because of the surprisingly thin stock foam in the seating area. This allows your weight to be distributed across the width of the seat, rather than concentrated in the middle, reduces vibration in the seat, and dampens road shock. These changes allow you to sit more in, rather than on the seat. The Supracor/LD material works for the rider because it is a dynamic material with an instant rebound. It moves with you, working with your weight shifts for proper bike control. If you use a material in the riders section that "takes a set" it locks you in one position and fights against you. This is the main problem with foams as the rider is constantly moving, even while cruising the highway you are making small corrections in your weight distribution.
With this the rider area can be lowered about an inch without causing any problems. While it doesn't sound like much, combined with the angle correction it makes a noticeable improvement in your reach at a stop. If you go any further it will cause the raised sides of your ZX seat pan to cause some serious inner thigh pressure in normal riding position.
zx14nsingle
zx14nsingle's Gravatar
San Bruno, California
RE: Any one sent there seat
06/05/10 12:09 PM
I had my seat done by Spencers and he is a very nice guy. He is pretty prompt to your emails but I can tell you he is extremely busy, because he does a lot of seats for FJR, BMW and Sports Touring forums. When I sent in my seat I wouldn't last 60 miles. I think it was partly to do with being over 200lbs and I start feeling the pan fairly quickly. After his mod, I don't worry anymore for any of my long trips. I've done 2500 miles on one trip and never had problems with saddle sore. Spencers is probably the most economical way to go and he does a good job.
ZZKENOMAN from the old forum
imrubicon
imrubicon's Gravatar
06/06/10 6:38 AM
I havnt sent my ZX seat as I like it taller . And could go another inch taller then stock ,
But Spencer is A+ , number one seat guy ever !!!!!!
I had him adjust my ST1300 seat and it was night and day on a longer trip.
Over on the ST-Owners site he has seats and reviews from easly over a hundred people that swear by his magic, This guy goes above and beyond service and is darn good at what he does. His workmen ship is good enough if you dont really find it great someone will most likely buy your seat as he has that many people that use his services. Much better first try at setting up a bike seat for yourself then swapping through corbin or sargent seats to try and find one that fits,
Hint to save a lot on shipping cut a box down to the smallest size to ship your seat as it can make 30 to 40 % savings in shipping which mean you may want to go overnight as then less down time ?
JMHO
Lost in TX and I dont want to be found ,
2012Yamaha Tenere 1200 for really wandering off the beaten path
2005 GL1800 Sold to another to enjoy
2006 ST1300 Gone but not forgotten
2009 ZX14 Also gone and will be replaced someday
some of the best of both worlds
rebus20
rebus20's Gravatar
06/06/10 7:34 AM
I have a sargent seat but its just the front. I need the stock one so I can put my saddlebags over the rear seat. I hate to ride 1400 miles on the stock seat without having it more comfotable. Plus if it turns out better than the sargent I can always sell it.
9secondsflat
06/07/10 5:32 AM
I called spencers up 5 times, emailed him to his aol email as requeste 4 times and he never called or emailed back....fuk him....buy a sargent and be done with it...
rebus20
rebus20's Gravatar
06/07/10 2:33 PM
I sent him an email and got a response the next day.
