Thread: Rear Tire Size
Created on: 03/24/17 01:12 PM
d04011
Rear Tire Size
03/24/17 1:12 PM
Looking at some new tires and wondering what size most folks prefer for the rear. Not looking at the brand for this thread but rather the size. On my C-14 Concours (heavier bike) I went with a 190/55 for a better turn-in ability. Wondering if I should also go that way for my ZX-14R or stay stock size 190/50? I also saw a 200/55??? Opinions by those who have experience on these options would be much appreciated. FYI - I have long legs so no problems with an increase in height on the back of the bike.
Current Rides: 2020 Triumph Rocket 3 GT; 2020 Triumph Speed Triple S; 2018 BMW K1600 Grand America; 2016 Kawasaki ZX-14R SE, 2015 Kawasaki C-14 Concours, 2014 Triumph Rocket 3 Roadster, 2014 Rocket 3 Touring, 2012 Harley-Davidson Fat Bob, 2011 Rocket 3 Roadster, 2009 Rocket 3 Standard, 1984 Honda V-65 Sabre
maddoxdb72
maddoxdb72's Gravatar
Elk City, Oklahoma
RE: Rear Tire Size
03/24/17 3:56 PM
I went to a 200/55 this time around. I like it so far. I think some with hugger fenders have had clearance issues. Also if you have a bigger rear sprocket and the wheel pulled forward you could have a clearance issue. I know a lot of guys go to the 190/55
RE: Rear Tire Size
03/24/17 4:20 PM
What maddox said^^^
I loved the 200/55 but the 190/55 is also a big improvement over 190/50.
I recently read a comment that 190/55 is the tire size recomended for replacement even though they don't give you that stock. That might explain why the speedo is dead on with a 190/55 and not with a 190/50.
TRAILBOSS
TRAILBOSS's Gravatar
RE: Rear Tire Size
03/24/17 7:12 PM
200/55. /thread
RE: Rear Tire Size
03/25/17 12:03 PM
like oil threads?
bfg9000
bfg9000's Gravatar
Cebu City, Philippines
RE: Rear Tire Size
03/25/17 6:56 PM
190/55
2013 Metallic Midnight Sapphire Blue ZX-14R + Brocks Alien Head 2 Full System | Spiegler Stainless Steel Braided Brake+Clutch Lines | ZG DB Windscreen | TBR JuiceBox Pro | Arashi Rearsets | BMC Street Air Filter | DME High Pressure Oil Relief Valve | Muzzys Oil Pump Cover | APE Flat Oil Drain Plug | FLO Reusable Oil Filter | Cox Racing Radiator Guard | GPR V4 Steering Stabilizer | CREE XHP-50 LED Headlights | LED Turn Signal Lights | Smoked LED Taillight | Targa Fender Eliminator | Tapemaster Strobed Reflective Rim Stripes | Ballistic Performance EVO3 Lithium-Ion Battery | Pirelli Diablo Rosso III tires
sharp609
sharp609's Gravatar
RE: Rear Tire Size
03/29/17 5:31 PM
200/55...can't say anything about a 190 because i've only run 200s on the 14...BUT, i have not complaints at all...i feel confident hitting corners, etc...no issues at all, and i like that way it looks too.
07 zx14.
..never let your EGO override your ABILITY.................burn rubber, not your soul....
OldMan
OldMan's Gravatar
San Jose, Sunny California
RE: Rear Tire Size
03/30/17 11:44 AM
Can you install 200/55 on the stock rim?
1973 Suzuki GT250, 1976 Kawasaki KH500A8, 1979 Yamaha RD350, 1985 Yamaha Maxim700X, 1987 Kawasaki EX500, 1994 Honda CBR600F2, 2004 BMW R1100S, 2005 Kawasaki Z750S, 2003 Suzuki SV1000N
RE: Rear Tire Size
03/30/17 12:23 PM
And with a stock chain and sprocket and clear the swing arm?
RE: Rear Tire Size
03/30/17 3:57 PM
No problem getting it on the rim and using it safely. It came very close to the inside front of the swingarm on my gen1. You might need to have a bit of chain stretch for it to fit. I have a little extra wheel base with my chain and sprockets setup.
ominousone
Twin Cites So Burbs, MN
RE: Rear Tire Size
04/02/17 7:02 AM
I just bought a set of the Shinko 005 with the back size being 200/50. I'm hoping it fits my 2016 ZX14 fine. I'll update in a week or 2 when they are installed.
ominousone
RE: Rear Tire Size
04/02/17 7:16 AM
Should be no problem. Will be like a 190/55.
ominousone
RE: Rear Tire Size
04/02/17 8:12 AM
That's what I was thinking, Rook. The Shinkos were cheap, had decent reviews and can't be any worse wear than the tires that came on it.
ominousone
* Last updated by: ominousone on 4/2/2017 @ 8:13 AM *
sharp609
sharp609's Gravatar
RE: Rear Tire Size
04/02/17 8:23 AM
I have a set of Shinko Verge on my bike...the 200...fits fine...rides as expected and has had good wear...no issues...getting the Metzeler M7RR in a 200...has really good reviews...
07 zx14.
ominousone
RE: Rear Tire Size
04/05/17 12:46 PM
So far I got the rear Shinko 005 on. This 200/50 ends up being no wider than the 190/50 BS that came on it. I wasn't expecting much different. Hopefully I can out for a ride soon and maybe report how I like it.
ominousone
