If any of you guys are running Ivan Performance's excellent flies out street map for slipons, you probably already know he developed the mapping using the popular Yoshimura TRC system although this map seems to work well with just about any slipon exhaust system and even the stock pipes. A full system requires different mapping and nets a nice increase in top end power from 6000 to 10,000 rpm with slightly more over run but you pay for it big time on the low end. One thing I did not know until I contacted Ivan, was that he developed the mapping without the Yoshimura Quiet Inserts installed. I had tried to remove mine but found the retaining screws had been welded in place so I left them in. Last weekend I had a little time on my hands so I got out the Dremel Tool and ground the screw heads off, pulled the inserts and whoa, what a difference! Without any apparent loss in low end, the midrange and up torque is nicely enhanced and the sound is much deeper and raspier. I have to admit I had gotten used to the incredible power of this setup but this definitely pegged the Giggle-Meter. If you have these pipes with the inserts, pull em out, I think you'll like it!
