Thread: Brake pad rattle
Created on: 07/05/18 06:10 AM
ominousone
Twin Cites So Burbs, MN
Brake pad rattle
07/05/18 6:10 AM
I have SBS pads, sintered I think, up front on my 2016 ZX14R SE ABS. They rattle in the Brembo calipers. They work and stop fine, just an annoying noise. Anyone experience this?
ominousone
RE: Brake pad rattle
07/05/18 7:30 AM
The EBC pads I swapped into my '06 rattled, they were a bit smaller in the frame than the stock pad so they moved around when the brake was applied. Not really a rattle but more of a click I could feel only when the lever was applied. The stopped no better than stock.
ominousone
07/05/18 8:14 AM
That sounds like what I have going on. In fact it sounds more like a "clatter". The sounds actually goes away when I lightly apply the front brakes. At first I thought it was coming from the inside of the fairing. My original pads squeaked when I applied the brakes, so this is an improvement in my opinion.
ominousone
* Last updated by: ominousone on 7/5/2018 @ 9:15 AM *
07/05/18 10:21 AM
Say one company has a patent on said design. Say the aftermarket makes a copy but the dimension is a mm off so it does not infringe on the original design. Something like that. The sound you're hearing is a happy sign that friction is not dragging the pads on the disc.
ominousone
07/05/18 10:42 AM
Excellent point Hub.
ominousone
