I did a search, but didn't come up with anything. I put a Zero Gravity Double Bubble on all my sport bikes. My question is, will an 06-11 DB fit on a 14R? I went on ebay and only found them for the 06-11.
Thanks,
Paul B
Created on: 03/24/13 12:13 PM
Bubbasdad
omega2k
RE: Zero G Double Bubble?
03/24/13 1:30 PM
I was told it would... I got mine at indysuperbike.com. And it fits. It was just a hair off as the bolts go, but nothing major. I got the dark smoke on mine.
I also got a lot of things from motomummy.com.
Indysuperbike had great deals on exhausts tho... If you are so inclined.
A quick run down of my parts are, akrapovic headers, yoshimura r77 slipons, pcv, Brock's Ecu flash, zg double bubble, Scorpio bike alarm, black and blue windscreen bolts and Bar ends and axle ends... All spikes from coremoto.com.
I am thinking about getting spiegler braided brake and clutch lines. I should be done :-).
I am going to get a demo and custom map once it warms up some.
Have fun ;)
carabuser
03/24/13 1:53 PM
From Zero Gravity website, the DB is the same for 2006-2013
$73 shipped at Amazon through the seller Leather Up. I have used Leather up many times, and have never had a problem, and never been charged tax, even though I live in CA, (where they are from)
* Last updated by: carabuser on 3/24/2013 @ 2:21 PM *
Bubbasdad
carabuser
03/24/13 3:19 PM
Even better, probabaly closer to where you live !
CurveKilla
03/24/13 3:54 PM
Carabuser, how do u like the kaoko cruise control?
robp69
03/24/13 5:28 PM
I just installed the same screen into my '13. The lower 2 holes with the hard plastic grommets wouldn't go (took the gear off of my old OEM screen) used a scraping tool (deburrer) to take a little out.
Not only looks good, but stops the head wobbling as much now ;)
I run a PC visor and with the sunnies, very hard to see the instruments sometimes!
Phantomx2k
03/24/13 9:01 PM
I love mine for sure! Wouldn't be without it. As for the cruise question I have the Vista Cruise throttle lock on mine and love it. You have to "schooch" the brake lever over a bit to make room and shave it down a touch but it fits in there and works fantastic. Not bad for $30.
carabuser
03/24/13 10:03 PM
Curvekilla, the Kaoko is very good, the only thing is, you have to get used to the opposite threads, I was turning it to lock it, and accidently hit the end of the throttle grip, damn near threw me off ! not kidding !
Bubbasdad
carabuser
03/28/13 1:09 PM
"It's killing me to have the baddest bike on the planet sitting in the garage, but snow on the ground."
Better safe than sorry .....
03/31/13 6:17 AM
I've got one on mine, this is the second bike I have had it on. They 0G is bad ass. Do you guys worry or ever experienced the bubble bubble burning up and melting your instrument cluster on a sunny day? Or is this a myth. I carry a cloth to put over my cluster when I leave her parked in the sun, I wonder if I need to continue this ritual. Thoughts?
carabuser
03/31/13 10:24 AM
Another angle of ZG DB
carabuser
03/31/13 12:15 PM
Wolfman,
Never had a problem with the DB, had one on my busa too for about 10 years, no problems at all ...
carabuser
03/31/13 8:50 PM
The 14 is like a busa on steroids, its like the busa, but does things better, it handles better, is faster, etc ..
my busa was a first generation, so the 14 is noticeably faster, not hat the busa wasnt fast ... very easy transition for me
03/31/13 8:56 PM
I just got a Zero Gravity Touring screen...they specifically warned about leaving the dash and all exposed to the Sun in a particular direction...It's not BS...They instructed HOW to park your bike to eliminate this possibility.For real.Not every screen will do this...maybe they'll NEVER do it with some...but it's been happening...hence the warning literature WITH the windscreen(s).BTW...this phenomenon is NOT mfg specific.
* Last updated by: Grn14 on 3/31/2013 @ 9:00 PM *
