Thread: Anything to be wary of?
Created on: 02/05/14 06:57 PM
biggmo77
02/05/14 6:57 PM
Installing a new chain and sprockets this weekend, along with a speedohealer. This is my first time with this particular project and I was wondering if there is anything I should be cautious of with the process?
I've read the tutorials and everything seems straight forward just want to be sure this and all future projects go as smooth as my past ones have.
Thanks in advance for any input.
I don't have to hate yours to love mine...
RE: Anything to be wary of?
02/05/14 7:24 PM
If you read my tutorials you'll know to be careful wrenching on the rear sprocket nuts, axle nut. That can tip the bike pretty easy. The output sprocket nut is sometimes quite tight. The rag wrapped bar through the spokes trick works well.
Speedohealer is a snap to install. Tutorial is here on that, also. Hardest part is calibrating it. But that Healtech site has a calculator that is spot on. ...careful of the white leads that go inline with the speed sensor wire. I am fairly sure they can short out after a bike wash with water. Don't spray the leads directly or your speedo and throttle may go weird on you. Clears by shutting down the bike and turning back on.
* Last updated by: Rook on 2/5/2014 @ 7:26 PM *
