I too have a '17 and sometimes it takes awhile to clear the code. So if the 6 hangs in the dash, it might be:
1. Connector not connected.
2. Wire out of connector.
3. Short or out of range is the gps.
Now you'll have to look down at the left [as you sit on the bike] down by the sprocket cover. Look for a green connector, light green wire of 4 at that connector. No wire out, right? Is connected, right? Then something is either short in the gps, or the flash is set for 6 and nothing is wrong with the gps.
So the question back is, was the 6 on when you bought it? Was N working when you bought it? If no, then sounds like a sensor or the N bulb is blown in the dash... just guessing here. If you lived close, we'd swap ECU's and find out if the flash is set to 6.
