What does your voltage read when you turn on bike, key only, prior to starting? I’m attempting to diagnose a weak starting issue that reared its head right after discovering a shorted wire that was blowing fuses. I’ve fixed the shorted wire and wanted to know if I caused irreversible damage to my battery, and if this is the reason my bike now struggles to start sometimes.
It seems that when the on dash voltage reads close to 13.5V, it cranks up instantly. If and when the battery voltage reads low 13’s - high 12’s, it struggles to start and only starts if I hold down the starter button longer than usual.
Thanks
