Hope you don't mind the dumb question.
I'm taking off the wheels to get them chromed. I have zero experience with working on the newer bikes. I want to be sure I have all the tools I need. I have the factory manual. I'm not sure about the removal steps.
I bought a 22 mm hex to fit the left side axle nut. The manual says to first loosen the left and right axle clamp bolts and axle nut, then remove axle.
Do I need another 22 mm to hold the right side of the axle or will the axle nut crack loose without it?
Seems to me the whole assembly will just rotate if not held? Or do I leave the right side clamp bolts tight and that will allow the nut to be loosened?
I appreciate the help.
