Adding a foot or two won't change the resistance much at all at DC but the connections or terminations will change the circuit impedance and could be changing the response on the pulse timing and the sensor thinks there is an error?
+1, almost certainly this is correct. Hagrid, too, by default :)
You're fooked.
The lines almost certainly have to be impedance matched for a balanced circuit, within a *very* small amount of tolerance.
Having said that, I don't know how you're going to fix it, now.
