Thread: Back from Nels at 2 Wheel DynoWorks!
Created on: 04/29/17 02:45 PM
clutchpack
04/29/17 2:45 PM
Hey TRAILBOSS...
* Last updated by: clutchpack on 4/29/2017 @ 2:48 PM *
skewedTotheLeft
RE: Back from Nels at 2 Wheel DynoWorks!
04/30/17 6:55 AM
Nice numbers
04/30/17 7:48 AM
TRAILBOSS
TRAILBOSS's Gravatar
05/01/17 12:03 AM
That'll do, pig!
What mods are you running?
clutchpack
05/01/17 12:04 PM
Brocks 4/1CT and a bmc air filter.
Cooldaddygroove
05/01/17 7:28 PM
Wat was the total time it took them to Dyno and tune?
Did they do a Dyno before the flash?
clutchpack
05/02/17 11:02 AM
Was about an hr with the pre run software loading and adjustments.
TRAILBOSS
05/03/17 11:16 AM
It's well worth the time, cooldaddy. I've got the before/after runs if you want to see them.
david5525
david5525's Gravatar
05/03/17 1:21 PM
Nels is very knowledgeable and thorough. He doesn't just throw in a tune and run the Dyno at WOT. He works with the mapping in multiple thottle positions and RPMs so that the performance is better throughout the bikes range.
I had a very good experience with Nels and 2wheeldynowork. My bike gained in dyno numbers and smoothness.
It was a beast before, but now it is a beast that inspires confidence to use that power.
Dave
* Last updated by: david5525 on 5/3/2017 @ 1:22 PM *
Cooldaddygroove
05/08/17 12:08 PM
Would love to see your before/after TRAILBOSS. I'll be starting with a full Yosh single sided system
