Sounds like the Cali desert. No, I will bring the harm... Point the direction.
While those idiots try to work their world out, [doubt it] I came back from my friend's shop. They were putting a bike on the dyno, when I finally had to go. Anyway, I said to my guy, what A/Fratio he runs. Simple answer = Whatever makes the most HP.
So for you to chase 13 or 12:1 ratios, one day the HP will change. So back to basics is to find that peak HP for that run. Whatever that fuel trim turned out to be, that ratio made the HP. So, map wise, it is OK for a download, but to gain the best HP for the day, that dyno will pull that number out.
That means, the variables are the room temp; how fast/slow the bike is being cooled, the outside temp and the humidity all factor in. Obviously, there could be a better day with better numbers. It's still a crap shoot.
