did the first oil change on the 14R, what a piece of cake not removing fairings and enough clearance to work...used my plastic filter cup wrench socket, filter came right off...drain bolt, same, I was hoping the filter would give me no trouble, it didn't...no surprises
252 miles the oil looked pretty good, still could see through it, definitely would not want to leave it in there for 600, but looked pretty clean...I run it in harder than recommended like I did with all my other bikes with good results(no under 4000RPM crap).......I put on a new OEM filter and regular Kawasaki 10w-40 oil for the first one, next oil change will probably be at 6-700 miles with Mobil1 4T....
