Hi Guys,
As of late summer my 14's engine makes a new noise at start-up, and only when it's warmed up. It is not cam chain rattle. I am very familiar with the cam chain noise and this motor only makes that sound when it is cold and has sat for some time on start-up. It does not make this sound when it is cold or even after it has only warmed for a couple minuets. In fact, it won't make this rattle/knocking sound until it has completely warmed up and it goes away within 10-20 seconds on it's own or if I bump the throttle a bit, as if oil pressure builds and it stops the noise. The sound seems to be coming from the top end.. but so far I can't tell if it's the right or left side. It also seems to be along the front side of the cylinder bank not so much towards the rear. Originally I though the sound was coming from the clutch area and back. The sound resonates all around the engine compartment and is very hard to pin point. Screw driver to the ear has not helped yet because I have not found the right place to pick up the sound and listen through the handle. Keep in mind I am only guessing at this point.
Now I hate threads about chasing noises because unless you can hear the noise yourself it's all guessing games and no real way to narrow it down. Add to that everyone has their own idea of what normal vs wrong sounds like, etc. Because of this I have made a high quality recording of the engine starting and making the sound at start-up. I have encoded it as an MP3 because it is the smallest, most compatible format used at this time. In this recording I start the bike 8 times. In the last few starts you can hear the fan has kicked on because engine was at normal operating temp. I let the engine run each time until the rattle noise goes away. I did edit the sound clip by removing periods of silence in between the starts but only to make the recording as short as possible.. and only removed maybe 10 seconds in between each start.
Stats and history: Bike is a 2007. I spun #3 rod bearing of my 2007 motor last year and replaced engine with a 2009 engine. I know what a rod knock sounds like on this motor.. this is not rod knock. The 2009 engine came out of a non-raced bike and was very quiet compared to the 2007 engine IMO. 2009 engine had under 4000 miles on it when I installed in my bike. I have since added close to another 4000. Noise is new within last 500 miles or so. Bike is garage locked until winter has ended... and I have not ridden it since October. I started it yest and let it warm up and tested for noise.. it's still there. Yes, I drag race the bike. No turbo, no NOS. Use only premium gas. I run some timing advance with an SB6 but not until about 5000 rpm. Never heard engine PING. Seems to run fine and pull every bit as hard as it ever has. Oil is under 500 miles old. Mobile 1 MC oil in 10 w 40.
Any ideas?
* Last updated by: motoCycho on 1/6/2011 @ 4:41 AM *
