Found a low profile drain plug for the bike at NAPA the other day. Figured I'd share with ya'll. It was like $2.00. part#BK704-1384
1975 Honda 754 super sport
2001 yamaha yz250F
1975 Honda cb 360
Created on: 05/02/14 07:06 AM
BUSAKILLER1987
Bopropucope
RE: Low Profile drain plug
05/02/14 9:03 AM
Looked it up on line and is this the one? BK704-1384 did not come up on line. These are the kind of posts that help everybody. Thanks,
Bruce
I was going to start to look for one and you did my work for me.
Product ImageLogo Image
Oil Drain Plug
Part Number: NOE 7041384
Product Line: NAPA Solutions
IMPORTANT INFO: w/ M12 X 1.5 Thread,w/ 17mm Head,5
http://s7d9.scene7.com/is/image/GenuinePartsCompany/NWMTMB?$Product=GenuinePartsCompany/1478606
BUSAKILLER1987
BUSAKILLER1987
Bopropucope
BUSAKILLER1987
customizedcreationz
05/02/14 6:12 PM
just a reminder for anyone reading, you need to cut off or grind the oil drain plug shield if you do this mod because if that hits, it will prolly break the oil pan whether you have a normal plug or a flushmount.
05/02/14 6:52 PM
^^^ just what I was thinking. Mine got a big piece missing! Glad the oil pan is intact.
BUSAKILLER1987
05/03/14 5:22 PM
wow! ...and with a brocks header! Does your header hit too or dis brock find a way to squeeze that up higher than the oil pan?
I believe it happened prior to the suspension upgrade and a little before I got the full exhaust! The header looks great even though I'm riding without the lower cowls
jm9814343
Bopropucope
