Had to replace the rear brake pedal assembly (original snapped when I had an accident). I bought a new assembly from a zero mile bike (or so the ad said). Anyway, part looks mint so no problems there. Installed it a few months ago, rode a few times on it and it "feels" ok. When installing it I had to make a few small adjustments in order to get everything set.
However, to me, it feels like the rear tire is dragging a little more then normal when I spin the wheel by hand on the stand. From what I remember (if im correct) the rear doesnt spin as easy as the front does and there should be some dragging from the tension of the chain. Is that correct? BUT, it feels like there is too much drag
I was thinking the new pedal assembly was too tight causing the caliper to have unwanted tension on the rotor causing the tire to drag a little. I checked the specs as per the manual and I cant seem to get the correct numbers.
Manual says in pic 1 between position A and B it should 45mm. My pedal was about 50mm so I adjusted back down to 45mm.
But then the manual says position C should be 80mm in pic 2.
Heres my problem. When position C is set to 80mm on my bike, the distance between A and B is 50mm (which is 5mm larger then spec. But when position A and B is set to 45mm, position C is no longer at 80mm.
This is what leads me to believe the caliper may be causing extra tension on the tire.
Does that make sense? lol.....What do I do here?
* Last updated by: bentz69 on 3/13/2016 @ 3:23 PM *
