Does anyone know if there is a way to install the 2018 ZX14R motor into a 2015 ZX14R? the gear selector sensor is completely different and so is the end of the shift drum. I do not want to open this motor up simply to change out the shift drum.
Created on: 02/25/19 08:45 AM
Kawipower
JimGnitecki
RE: Motor swap
02/25/19 12:00 PM
If there are subtle differences like THAT, then I would also wonder if you will need a new ECU. IF there are mechanical differences, there may well also be electrical system and ECU differences, and a simple reflash will NOT correct that, as the commercially available reflashes only address specific performance-related data fields and code, not ALL code.
Furthermore, once you install a 2018 engine into a 2015 chassis, you have a mismatch between ECU / engine / chassis, and might not be able to find anyone outside the Kawasaki design center that can make them work together properly and fully.
This swap sounds risky.
Jim G
Zxpredator
RE: Motor swap
04/11/19 3:51 PM
Can I swap a 2018 ZX14R engine into a 2015 ZX14R frame? Yes.
Is the end of the shift drum specific to the gear sensor? Yes.
Will the 3 sensor wires [still match] from sensor to main harness no matter the year? Yes.
Do I need to swap the sensor connectors to return the wires back into their designated locations? Yes.
Should I make a tool to depress the tangs in the connector so I don't squid the wire integrity and/or connector? Yes.
Signed,
NOLTT (no one likes tang tools)
beck6
RE: Motor swap
05/26/19 8:39 PM
Can you find a similar engine? There is a lot of reference here https://www.allicdata.com/blog
