Apologies for the following mess, may be
a pretty tough and tedious read, so
in summary, I need a source/link for the exact
OEM match in Banjo-Bolt Washers.
I replaced my front brake cables (2013 ZX145R)
with aftermarket cables, and thought I had lost
one washer, I've bought two different packs of
washers and still have drippage.
It has been super difficult to actually find
the correct washers, the specs listed are not
the specs I'm receiving and now I'm finding
that there seems to be some 'weeping' out of
the upper double banjo bolt assembly as well
as one lower bolt where I'd replaced
that washer.
What are the best washers to use?
The ones I've gotten so far measure
9.75 ~ mm id
13.76 ~mm OD,
I think they should be 10 and 14mm exactly and
2mm thick, but what material; copper, alum or?
The thickness on the first set was 1mm (way too thin,
did not work) , and 1.35mm second set, was
better, but not great and as mentioned these
are all measuring about 9.74 id and only 13.75 od. "
The more I consider everything related to my initial
brake problem, the more I'm thinking the front lines
or one of them had a total clogging issue as I think
was suggested by @rook or @hub, someone else mentioned
a valve somewhere.
Should I soak the possibly clogged cable/s in brake
cleaner and try them again?
Either way I definitely need to replace at least
1 OEM banjo bolt washer with an equal, I have yet
another set of banjo bolts on the way and if the
included washers still suck, I figure on taking
a banjo bold to O'Reilly's and see if I can't come
up with a 'proper' washer match.
