I had a question that went unanswered and I may not be alone. The Helibar website does not list their risers as fitting any ABS model of zx14R. They do. No mods required.
Created on: 06/26/14 10:16 AM
ZEROPILOT
Helibars DO fit the 2014 with ABS!
06/26/14 10:16 AM
ZX14R
doubleD
RE: Helibars DO fit the 2014 with ABS!
06/29/14 12:01 AM
I have a 2012. I mounted a GenMar spacer. It was 1" in thickness. It fit without moving anything.
I followed the brake hose from the master cylinder down the right fork leg. There was a junction box-metal it was bolted to the lower triple clamp. I believe that is where the ABS system connects to the front.
Check your Bike.
Here is a partial photo of the ABS system. Most systems use metal plumbing when ever possible.
Unbolt the brake side and see how high you can raise it.
* Last updated by: doubleD on 6/29/2014 @ 12:03 AM *
