Thread: Brembo 16RCS Clutch master cylinder upgrade, Done! Cheers, mate.
Created on: 04/26/21 02:22 AM
Alom
Alom's Gravatar
New Question....Brembo 16RCS Clutch master cylinder upgrade, Done! Cheers, mate.
04/26/21 2:22 AM
Thank you for your help, guys. everything is ok. easy to install, especially the spada connectors for clutch safety switch. took me around 3 hours to finish it. it need more time to adjust it. you can't believe the most difficult part was installed the small clips on the rubber tube........
* Last updated by: Alom on 4/26/2021 @ 1:57 PM *
Alom
Alom's Gravatar
RE: Brembo 16RCS Clutch master cylinder upgrade, Done! Cheers, mate.
04/26/21 1:56 PM
One more question, how to check if the mc works well? I got very different feeling when I tried to do gear in/out. I already set the distance of the lever to maximum. But I am not sure if the lever is pulled in completely.
I am very grateful for any help.
Zxpredator
Zxpredator's Gravatar
05/21/21 11:48 AM
https://youtu.be/ERXVu8NRJ-0
i did this mod a long time ago. here was the process
