There ya go Kruzinator. If the 10's cooling system is situated pretty much like the 14's, that should help you drain and disconnect all hoses from rad. Save all of the coolant to pour back in when reinstalled. Then it's just 3 screws and the thing will drop right out. Weighs ~3 lbs dry. Refer to details on bleeding when you refill the system.
I straightened all the rock strike dents on my 14's rad when I removed to install full system last summer. I just used the blade of an exacto knife. The fins are just a little stiffer than tin foil. They bend back real easy so be careful. You will get that thing like new again. The back is no different than the front for fixing bent fins.
If the bent rad fins don't bother you too much maybe you might as well just wait until next year and replace coolant while you are at it.
nah --you'll have to have that thing pristine, right now, hey?
* Last updated by: Rook on 6/29/2010 @ 1:44 PM *
2024 ZX-14R bran friggin NEW!
