Thread: Brembo Clutch Maintenance Bleeding master cylinder
Created on: 07/07/24 12:14 PM
Zxpredator
Zxpredator's Gravatar
07/07/24 12:14 PM
https://youtu.be/zyHcmq4UF60
@rook gave you a shout out.
RE: Brembo Clutch Maintenance Bleeding master cylinder
07/07/24 5:26 PM
Thanks Zxpredator, I have recently started visiting the forum daily. The period of doldrums I experienced lasted 2 years but I'm back full force now. I took my first ride on my 2024 ZX-14R today!
One thing I might try if I need to drain all brake fluid is to refill the system from the bottom using one of those vacuum pumps. I'm not exactly sure how that procedure works but I can see how it would eliminate air pockets. I'm glad you got a good Vacuum pump. The one I bought must have been defective. It produced very little vacuum and simply didn't work for sucking fluid out of the bleeder valves.
Zxpredator
07/29/24 11:07 PM
Thats interesting to fill from the lower area. I might try this next time.
