If those two are the only ones you have...yer missing the right side set(s).I wouldn't try riding without those...might get a serious surprise when you look down where yer puttin yer right foot.Did you check your hoses on the right side?That's where they'd be attached to.(except that square one...that's on the belly fairing).I know one of those bigger ones rides under that midfairing at the "belly/midfairing" seam.Down over the tip of the Pulsar cover there on top.That other one rides across the engine case there,attaching to the rad hose.In the back of your manual...in the APPENDIX...you'll find the diagrams of the "hose configurations"....the placements of all the foam pads are right in there somewhere.Very clear.Good Luck!
Maybe mine DOES have three on that right side..hmmmmm....probably.Whatever is supposed to be in there...it's in there.I'm pretty good at reinstalling stuff(usually)LOL!
Ya..okay...mine does have three on the right side.Yes.The bigger long one goes "up top" kinda...the longish tip going over the top of the pulsar cover and down.That smaller triangular one is attached to the rad hose under the fairing.That square block is attached right about at that convex bump on the belly fairing,keeping the fairing from contacting the engine case.
Tell ya the truth...I'm "kinda" like that shmoe in "flight of the phoenix"...that guy that "designed" that plane to fly outta there....you know...his only REAL experience was.................assembling MODEL airplanes!Yep...that'd be me.Used to spend HOURS building and painting my model Helicopters and planes...when I was a wee lad.
* Last updated by: blue07 on 3/7/2011 @ 5:06 PM *
