I plugged the hose going to the air chamber to lessen the decel' popping. It helped some.
Now I noticed the gas mileage drop a couple mpg. I'm pretty certain nothing else is wrong.
The fresh air system only effects the already spent gases, correct?? So the ratio of gas into the cylinders shouldn't be changed?
The bike seems to idle a bit uneven too. Awhile back I had a similar issue caused by filling the tank too high. I lost a good 5 mpg and the idle was even more choppy/uneven and much more obvious. I shot some air into the hose under the seat and that cleared the system of about a tablespoon of fuel and the bike ran fine. I tried that this time and almost nothing came out.
So I'm wondering is plugging the hose can cause problems too. I know many owners have plugged that hose. Any help appreciated.
* Last updated by: KAK on 8/21/2010 @ 10:11 AM *
