Welcome...great choice there...ENJOY!!!!
The "F" button is full power,the "L" button...70% power or so.Traction Control settings..."1"...least interference..except for "off"(which can only be set when bike is not moving and will default to '1' when key is cycled).Will allow wheelies...to a point."2"...more intrusion...will somewhat stop any wheelying...though it still will wheely if done a certain way."3"...'rain mode'..that is...it will intrude the quickest of the three to stop any slide,or wheelslip on slick surfaces.Probably won't use this unless it's raining or the road is compromised.
Hope this helps...You have ABS...FULL continuous pedal pressure with this when emergency braking.Do not let up on the pedal in such situations.You'll feel the pulsing going on...that's good.
* Last updated by: Grn14 on 9/27/2015 @ 9:26 AM *
