In my experience Pirelli tires have very stiff sidewalls but I've only used more race oriented Pirellis. I've run 25 psi front and back for Super Corsas and Diablo Superbike Pros in the twisties. I even tested them at lower psi at low speed and they didn't feel squirrelly like other tires do even at 25 psi. I think 25 psi is low enough.You'll find the tire pressure increases when the tire heats up. The air inside expands.
Right, thanks.
The tires I took off were the original OEM's lol,
hard as a rock. When I got the rear delivered yesterday
I was amazed how nice and grippy the tread felt.
Stiff or flubby sidewalls is not something I
would be able to tell the diff with at this point,
maybe down the road, I'll be able to tell.
I am aware of a hot tire having increased PSI,
so this becomes a bit complex in as much as
the explanation I was talking about earlier
was not something I had previously considered,
they were saying when cold out, the tire
needs to have less pressure than when it's
hot where we are riding, and that made sense to
me in that a cold tire is stiff, and hot tire
the opposite.
So the issue is a bit over my head when weighing
psi hot cold, not going to keep me off the road
though, I'll just try not to go to either extreme
with my psi.
Right now, most of what I'm doing is sweepers
and slow maneuvers, I'm at about 34 to 36 psi,
very happy with my new tires, and tomorrow am
it will be about 45f, I'll drop them down to 28ps
and see how that feels.
It will likely warm up to 80f in the afternoon,
do you think it is reasonable to keep my tires
at about 28psi (checked 'cold')?
I had been able to change the front tire with spoons,
I was not able to finish mounting my rear wheel
yesterday with spoons, I wore myself out, spending
way too much time and effort, finally took it to
a tire shop and had them finish it off.
I had been watching all the videos on EASY tire
changing, but I kind of realize now that all
of the videos that I watched seemed to have
pretty generous sidewalls,
these 190 50 17's have almost no sidewall.
