Thread: Oil filter wrench size
Created on: 05/28/14 05:15 AM
ZEROPILOT
ZEROPILOT's Gravatar
Sunrise, Florida
05/28/14 5:15 AM
Does anyone know the oil filter "cap" wrench size for our ZX14Rs? I mean the outside diameter for a cap wrench. I'm looking to buy one from Snap-on.
2014 green/black ZX14R ABS. 1972 Kawasaki H2 Tracy bodied. Reed valves. 2000 Kawasaki ZRX1100. 1977 Kawasaki KZ1000 cafe.
RE: Oil filter wrench size
05/28/14 5:49 AM
good thing to have if you want to torque to spec but I think if you do, you will find tightening by feel better. Isn't the spec for the filter something like 13' lbs? Seems to me that would be a beotch to get off. I just turn till it touches and then go a half turn more. Never leaks, comes off pretty easy. I use a universal type filter wrench and if it starts to crcush the side of the filter when installing that is a sign to STOP. Maybe back off a bit. After having one or two filters crush down when removing, I learned snug is good enough. A socket would be a god thing to use on a stuck filter.
I bought a filter socket for my car and it seems to have worn out a bit after 20-30 oil changes. It will slip when i take the filter off. May be that some filters have slightly smaller flats than others. I line it witha rag and that seems to help. Snap-On should have good tools though.
* Last updated by: Rook on 5/28/2014 @ 5:51 AM *
ZEROPILOT
Sunrise, Florida
05/28/14 7:46 AM
I found it. It's a 14 fluted (sided) 62mm cap wrench. It also fits most Toyotas and Scions. I'll be looking for one that's cast aluminum and not the cheesy stamped steel. It's crazy expensive from Kawasaki, so for me, that's not an option.
05/28/14 8:12 AM
The oil filter "cap" wrench should be the same as the Gen 1. I bought mine at Autozone for $5.99. You can find it HERE...
carabuser
carabuser's Gravatar
05/28/14 9:54 AM
To loosen, I use one of these, works on everything !
To tighten, what Kofla said ....
* Last updated by: carabuser on 5/28/2014 @ 9:58 AM *
Predator Race Team #14
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
ZEROPILOT
Sunrise, Florida
05/30/14 3:26 AM
I found a very strong, forged aluminum one on the Snap-On truck from "BLUE POINT". It's actually a 64mm for Toyota and Lexus. It's made for high torque applications...Like removing the factory installed filter. I dont think the auto parts store ones would last very long. (I also read the reviews.) This one is about $25 and I can use it on my bike, my Tacoma, Yaris and Scion X.B. Thanks.
05/30/14 7:31 AM
Hell yeah. I had a dickens of a time getting that sucker off.
TRAILBOSS
TRAILBOSS's Gravatar
06/02/14 2:29 PM
I always go hand tight plus a 1/2 turn, by hand, much like Rook. I remove the filters by hand, or with a large set of channel locks if they're too tight. Been doing that for 7 years and 6 bikes. Never a problem.
The filter is actually the only part I never use a torque wrench on. Everything else gets torqued to spec.
ZEROPILOT
Sunrise, Florida
06/04/14 10:21 AM
Is there enough room in there for channel locks?
carabuser
06/04/14 12:19 PM
Get one if these, it's only $6. Mines a different brand but it works 100% of the time ....
Autozone filter wrench !!!
Review from a autozone customer :
"My oil filter on my 2008 ZX6R Kawasaki cycle was ridiculously tight and hard to get at. I stripped one plastic and one metal cup type made for my bike, trying to get it loose. I even tried channel locks and filter pliers. I was sick. I got up this morning, went to auto zone, bought the 25128 wrench. It took less than 30 seconds to solve my tremendous headache. I still don't believe how well it worked for my application. Auto Zone Rules!"
* Last updated by: carabuser on 6/4/2014 @ 12:25 PM *
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
