18mm O2 bungs are pre-installed PCv has the 02 but for a single 02 plug in? Brock uses dual 02's and might not have a 3rd for a single sniff off of the 4 pipes. You would need a bung at the collector where all 4 pipes feed into 1, so the one sensor reads all 4 cylinders.
From Brocks: "Dual O2 bosses allow independent Air/Fuel measurements in headpipes 1&2 and/or 3&4 for more precise cylinder ‘trim’ measurements." I would assume you have the 18mm plugs installed when you receive the exhaust system. Then, you can step down to the PC-3 without any 02's being used. Better make sure the PCv has access for dual 02's or it's a waste of a bung location, unless you run two Pee See about that wire job. Besides, I've not read up on the latest FI aftermarket products to know if you can run dual 02's. Call Brock on that.
YOu did not say if you are using this for race or street. You made no mention of flies in or out of the throttle bodies. Here is where you can get away without using a piggy; if the subs are in play. Technically, you can run without damage to the bike being the fuel trim is preset, the 14 does not rely on the 02 to calc a fuel load.
The approach to the tune is; where are you going with this? Ask yourself, how much tune do you want to throw at it? I would ask myself these few questions and answer with:
1. Am I ever going to race in a closed course, be it straight line or curves? We do not have optimum ground clearance with this style pipe. What am repeating is more the generic go pick a pipe and here is the problem juggling if I need said fuel cutters? Yes, I want the PiG for max performance, I'm taking it to the edge is have it there when I get dare.
2. Will I bust balls on the roads, never pay for 1/4 mile times or trackday is do it on the street is play there? Well, yes again. If I have that type spirit to come up against some fun is happen chance? I want to be ready is what have they got is match dare ass is, next...
3... Say instead, I'm the kind of guy that needs a good sound, I'm sick of stock or like slips is better looking for me. I'm thinking, there are guy/gals reading this, would rather pass on all that tech stuff, would rather ride with my one big mod. Kind of change things around, I can get away with just a pipe and haul on the street, the bike... The bike is fast enough, I'll never use that much power is just taste some of it. Then, no, I do not need a piggy. I understand the concept, that if I WOT the throttle as fast as I can with the bike in neutral, that tells me the electrics fed that fuel all the way up the rpm range to the limiter no matter how fast I can snap the throttle, the air speed followed. Show me a lean condition.
Slow me a lean condition I'm not beating that bike every time out is wind it up a lot. No piggy, no subs, a gutted pipe makes it 4-in-1 is the faster flow is one side with the one door open more. No engine damage is hear the sound of that note. Know you're facts from fallacy, you need to tune the bike to the moon.
"Chug-Chug, Cough-Cough UP a map someone... Mine smells BaDanShit."
Say nut inn 2 know won.
