Thread: 40 Tooth Rear Sproket Questions
Created on: 03/25/22 06:11 PM
jokacz
jokacz's Gravatar
03/25/22 6:11 PM
Ok, so I'm going with Rickey Gadson's theory that a 40 tooth rear makes it easier to launch a stock wheelbase 14R at the strip. Can I get away with a stock length chain, or is it too long? Can I cut down a stock chain and add a master link? The stock chain looks weird to me, not sure it will take an after market master link. Any advice appreciated. Thanks in advance.
RE: 40 Tooth Rear Sproket Questions
03/26/22 1:03 PM
That's only one tooth down on a Gen1 so I think the stock chain would work and give you a little extra wheelbase. Get the 40 T sprocket and try it out. As for removing a link and rejoining the chain, it looks like DID makes 530 master links. Get a quality chain breaking/rivet tool. Stay away from the snap ring master links.
That's a beautiful 08 you have there. Wish I had mine back (in one piece).
jokacz
jokacz's Gravatar
03/26/22 9:52 PM
Thanks for the reply and the complement, but I traded in my 06 for a 2015 14R, haven't got around to changing my Avatar. 14R has 42 teeth which is why I was wondering if the stock chain would be too long. The stock chain on my new bike doesn't look anything like the chain on my old 06. I guess it's a 530, but it just looks wimpy, smallish links. I'd never use a snap ring master link, I like the EK screw type master links.
* Last updated by: jokacz on 3/26/2022 @ 9:58 PM *
03/27/22 8:54 AM
Yes, I've been told the kind that that a nut that threads on each pin, then you torque the nuts and snap them off mushroom the pins perfectly. I guess you could try hacksawing the old chain off if and when when you need to. I only made it halfway through with a hacksaw. I guess a handheld grinder then. A bit brutish but it should work.
For reference, I had a 45T rear sprocket on my 2008. It required a 118 pin chain which is only one link more than a stock length chain on a Gen1. Even if you're going down 2 teeth on the rear with your Gen2, I think your stock length chain will still work. I'd have a look at gearingcommander. I'm sure they have a calculator for gearing and chain length although I'd only use that as a reference as well.
* Last updated by: Rook on 3/27/2022 @ 8:55 AM *
jokacz
jokacz's Gravatar
03/27/22 9:25 AM
I put 50,000 miles on my 06 ZX-14 and went through at least 3 chains. If you use an angle grinder on the rivets, just a Harbor Freight chain breaker is all you need to remove the pins. It will even peen a hollow point pin master link. You need a super high dollar breaker to peen a solid rivet the way the factory does. One of my concerns is that if I use the original length chain that it will put me at the extreme end of the adjustment range, if it works at all. I did look at gear commander and the answer was a bit nebulous.
03/27/22 8:55 PM
Good luck then. All you can do is try the chain with the sprocket unless someone who has tried it chimes in.
