Hi Guys, thanks in advance for reading.
Is there a catalytic converter in my header pipes or any other restrictions ?
The headers are the ones it came with.
Thanks lots, lost with out you's
Maddy
* Last updated by: Maddy on 10/3/2019 @ 12:54 AM *
Created on: 10/03/19 12:53 AM
Maddy
Cat in my headers
10/03/19 12:53 AM
Maddy
piken
motoman97034
RE: Cat in my headers
10/05/19 11:33 AM
the 2013 does not have cats in the headers.Only in the muffler.It does have a couple of flow vanes welded in inside on the collector area.These do not affect performance in a negative way.If you remove the muffler you will see the cat material right there at the fitting of the muffler piece.
* Last updated by: Grn14 on 10/5/2019 @ 11:35 AM *
Maddy
Sincity14
05/25/20 7:53 PM
You've probably long since figured this out but, the stock headers on the gen 2 have 2 big cats right at the very end, one behind the other, if you have slip ons, take one off and have a look. I kinda "blacked out" one afternoon and they mysteriously vanished... Anyways if your thinking about the last cat delete, consider good mufflers -_-..unless you enjoy your ears bleeding after every ride..
