Thread: grease instead of chain lube
Created on: 09/07/12 09:57 PM
09/07/12 9:57 PM
Years ago,the H1 era, we use to heat up grease to liquify and paint it on the chain,anyone still do this?
Neilp
Neilp's Gravatar
Brisbane, Australia
RE: grease instead of chain lube
09/07/12 11:12 PM
I havent done that for years, used to pull the chain off but it in a bucket of grease & then heat the bucket up until the grease was nearly liquid. Then pull the chain out & left it to drain overnight!
But chain technology has come a long way since the introduction of O rings, better quality steel also.
Neil
09/08/12 7:39 AM
I have used grease instead of wax in the cold weather cuz I think wax is too stiff to be a good lube at low temps. What I havce found is that the hightemp grease mucks up around the front sprocket quite a bit. It doesn't melt and drip away readily because it is designed for high temp use.
skiffman
skiffman's Gravatar
09/12/12 8:07 AM
Grease will be a fine way of lubing your back tire......,Even EP grease will heat up and fling. Use products meant for chains. As mentioned O & X ring chains are far superior to anything we had back in the 70's. So is the available chain lubes.
06 14 Tuskigi stainless pcIII w/custom map.
Penske shock. GP North forks
Custom Leather seat
And too many other mods.
Track Bike morphing into a sporttourer
ZG touring screen, risers, Buell pegs, etc.
And a couple of other Kawi's
motero
motero's Gravatar
09/12/12 9:24 AM
get a chain oiler and be done with it!!
oiler review
i use the scottoiler
2012 black zzr 1400,
sherco 290
sherco 305
09/13/12 4:54 AM
This is true. Still think petroleum lube has better ;properties for lubing at low temps than chain wax. Have not tried any other lubes.
High temp grease I have used stays on the chain for 500 miles but it flings. Not really a problem except it bugs me that I have grease dropping out from behind my sprocket cover. Apparently, the high temp helps keep it on the chain but also, it does not melt away as easily as other petroleum products.
